Hello i hope its ok for me to post this here, my name is james im 23 years old and ive just started 3d modeling. i used to level design in Hammer so i am used to brush modeling so bear with me as i learn my way around more complex 3d work.
so here is my first attempt with 3DSmax.
The 120mm "Diamondback" air supperiority/anti munition weapon is the big brother of the ground vehicle based "Viper" cannon which is the single barreled version. The weapon is a quad barreled 120mm cannon with a rate of fire of 450rm and has seen use on both ground,air, and vaccum based vehicles.
edit: forgot to add other image.
please forgive me if my spelling is terrible and i hope you can help me improve my work.
and here is a close up of the sensor pod and the "sunchild" countermeasure launcher.
The texturing looks a bit...colourful...but that could be to due to the lack of better textures, or some other reason I don't know! But you're the person making it, so long as you're happy with it, to heck with my opinion. But yeah, it looks cool and vicious, especially after you beefed it. It looked a bit broken up in the first two pictures.
So you could change that and see how it looks/feels.
Also this site might be a nice source for inspiration if you haven't found it already.
http://www.rheinmetall-detec.com/index.php?fid=1368&lang=3&pdb=1
And although I assume you already looked these up I still link to them as just in case:
goalkeeper CIWS
Phalanx CIWS
ive increased the size of the ammo link and added a seperate one for the lower guns. ive re coloured it so its less all over the place.
a close up of the autoloader from behind the AA turrets
and 12 inches of frakking diplomacy
with four tri barreled cannons fill the sky with enough munitions to diswade any air assualts.
Pumping out 15mm fragmenting airburst munitions at a ROF 60,000 Rpm the weapon earned the nickname "The princess" as its demands for parts and ammunition are high.
The system is also one of the few "viper" series to not have its own sensor systems and relies heavly on both Radar stations and Recon mechs.
And honestly that ROF is a bit out there as the GAU-8 can only 4200 rpm and that is a Gatling system.
hmm, maybe I can offload an idea of mine unto you which is a salvo tround Gatling gun.
Some number crushing; I'm certain that you can make a tround with 6 shells in it so with a less out there rof of 5000 rpm you can get 30000 shells on to the target in a minute.
(Realistically most engagement only last 1 or 2 seconds resulting in "only" 500 to 1000 shell on to the target)
On the other the hand you have metal storm system but other than giving a ROF of 60000 rounds per second it's really boring. :P
I like big guns, can yeh tell?
lots of cooling apparatus on that one and it has "plugs" on the back for its power use.
The Odysseus, a two hundred and twenty metre long light utility and recon vessel and was the first ship built by the NRA (non related alliance of mankind).
she has a top speed of 38580 mph over twice the speed of the current NASA shuttle (its closest competator)
built in 2018 after the foundation of the NRA its maiden voyage took place on Novermber 21st 2021 and started her trip to Mars.
capable of both atmospheric and vaccum travel the Odysseus is a single stage vessel that unlike many other nations space programs does not require a rocket to launch.
Her engines automaticly switch over to a turbofan system when the ship enters the atmosphere.
with a crew of twenty five with full medical and science staff, and the cargo space for around ten months travel supplies.
(heres the landing gear its animated up and down.)
The Odysseus later had sister ships built the first being the Pegasus in 2022.
its wip obv guys but let me know what you think or if you want any more infor about the ship or the Black ships universe.
edit; added a version with a few changes and added weapons.
airlock animation test aswell
http://www.youtube.com/watch?v=pX9n0XEkY4g
LOL, actually Grox, those are regular colors Max puts on a standard object.
I do think things are missing some detail, and it would be nice to think of your designs in context of the period and the usages (roles/situations) they will be used within.
Your air lock animation is excellent though I feel a little more thought could have gone into the concept for the Odysseus (the leg's seem way out of proportion, and the external jet engines(?) seem like an after thought.
Either way great first modelling session, please continue!
first up is a close up of the crew airlocks with added details suck as securing rails and panels.
next is a close up of the experimental comms unit.
here's a shot of the repositiond cargo airlocks.
and the landing gear that seems too skinnynow
shot from behind.
front shot as of today with alot of added details
as you can see ive added armour around the engines and added its support struts.
and here's a close up of some added details suck as panels and a cargo crane.
and one last thing a quick mock up of a fighter.
C&C welcome please comment anything that comes to mind.
The best positioning for any CIWS is at the nose and one at the rear as it give the best coverage.
now heres a few new shots.
and a sneak speak at what im working on next you might just be able to see the Oddy in there to give a sense of scale.
heres a better shot of the new ship just called scorpion atm. the Oddy can fit inside on of the 4 docking ports on the "wings" and green lumps are Anti fighter weapons each can engage 4 seperate targets at once. more details to follow if people want them.
This is great!
I would be very happy if I could model like you can.
one of the lancer and the hedgehog.
and something completely different i desided to have ago at a star trek ship. so i brainstormed an idea of what type of ship i wanted to make i knew i didnt want to do one thats already been made, so i came up with the Rogers class ship. it always bothered me that there were families/civilians on starfleet vessels i thought they would just get in the way in emergencys so the rogers class is an Aclimation vessel for civilians who are living on ship to have a basic training/idea of life on a ship.
But I can't warm up to that Star Trek Ship. Is there a second warp nacelle underneath that halfdome?
Where's the bridge? Isn't it awfully risky to have that dome there and not say underneath the main body or above it?
But those are just my thoughts.
