3DLDraw Cobra MKI
gernot66gernot660 Posts: 0Member
this is a rough LDraw model. time to workout; ~2 days. it has to be transferred to and reworked in blender to fit for ffed3d
if you like LEGO, you will like LDraw. try, i await your results :D
Post edited by gernot66 on
  • Dr-TimelordDr-Timelord0 Posts: 0Member
    Ha! Thats pretty cool god i miss Elite
    they shud bring it back!
  • CoolhandCoolhand241 PhobosPosts: 1,273Member
    you're putting lego blocks into it... what poly counts are you expecting? heh. man they got pissed off at me because i was a couple thousand over their arbitrary limit.
    mr baker, you should check out FFED3D. its back and basically the same*, but with some new spiffy graphics and a couple of mods by yours truely, though i'm not sure if they're included in the collected download.
    *same as ffe/frontier. if you want to play something more like the original elite, ooolite i guess would be for you.
  • gernot66gernot660 Posts: 0Member
    at least i was able to reduce the shuttle (other wip) from 155k to 9k, still 10x standart ffed3d, but it works well.
    in the end only the "shell" will be left, (unseen)blocks and all studs will be removed, i know a lot of work, but keeps the LEGO style to 95%. i could have used a different scale to reduce the amount of blocks used, but then the models won't fit to the minifigs (lego people).
    update
