3DWill's Model Masicare
experiment442experiment4420 Posts: 0Member
Well, here's a ship I've been working on for a little bit.
At the moment I'm calling it 'battleship thirty-twelve' for some reason. Its roughly the same size as the daedalus with the same role. Just made with new tech in mind.
Post edited by experiment442 on
    nice details any close ups of those turrets? Ha was just thinking are you going to finish this model? I know my attention span is small also hopefully I will finish my current one!
  • experiment442experiment4420 Posts: 0Member
    This is a new one, got a full render in the works at the moment then I'll do a close up on the gun. Still some tweeks to make to it and some more textures to add, then this seciton will be pretty much done, also those little blank spots by the side.
    Here's the close up shot of the five hundred millimeter railgun.
  • asddsa0147asddsa01470 Posts: 0Member
    Looks different than Daedalus, but also pretty nice.
    Its supposed to be different to daedalus, basically battleship thirty-twelve is a story as well as a ship. Part of Tales of the Tau'ri Empire. (fan fiction I'm writing) There are eight main 500mm railguns and I'm probably going to add in two of the asgard beam weapons. A few smaller double barrel railgun turrets and some silos. The wings on the side of the neck are getting redone soon and then there's the super structure to add on the right side of the rear of the ship. Any suggestions and ideas that might help me along in my detail/model in general would be very nice. :)
  • meugen06meugen06334 Posts: 5Member
    Maybe add some forward drone tubes and increase the plasma turrets to 6 maybe 8 so you could have a strong fire power.
    They're 500mm railguns, and there aren't going to be any drone launchers, nuke launchers yes. You always need a few nukes on a spaceship.
    There are eight 500mm railguns...
    Yet again I've drifted from the matter at hand and have decided to work on the GWMC (yay...) Its a high tech naval vessel this time, and here's what I've for so far.
    Done the basic shape, haven't done much more though. Had a lot of school work this week. Hoping to get some done tomorrow.
  • JennyJenny2 Posts: 0Member
    Why are you calling them 500 mm railguns, v. 50 cm railguns, or even 0.5 meter?
    That's the proper term for a weapon.
    12 inchers aren't called 1 footers.
    why not just have 20inch guns rather than mm. In naval terms the larger guns are measured in inches not mm.
    Not a fan of the future ship it just looks like a runway and hanger on a boat there is no distinct design to it if you get me?
    At the moment that's all it is. :p
    I just downloaded kerky and I'm mostly lost, Got this done though.
    I'll never finish the boat in time due to a certain game retailer that didn't refund my purchase of Mass Effect 2, going to ring up the manager today. That should sort it out. I'll be continuing with the other ship from now on, I think I have kerky in the bag now.
    kerky + me = oil + water
    Podium + me = Water and... Whatever goes good with water.
    Been gone so long because I've been sticking with LS-A for a while... And my sig makes me sound like a telemarketer. :lol:
    Here's a big tanky render to get the thread up and running again:
    Uploaded with ImageShack.us
    Working on the inside of a ship :) Its 204m long and will probably have around 10 decks and a ton of rooms and corridors to greeble. Deck 1 is finished, starting work on deck -2. (There is no deck 0) Due to sci-fi meshes' ability to not let me upload as many pictures straight from my computer, most of this will appear on LS-A in the 'will's moddel masicare' thread in the 3D wips section. Or, you can wait a while for the next update, its easier just to visit the site...
    (^Door to door salesman...^)
    Didn't like the old one, based too much on walkways rather than ship components. This one has an equally bad body, but a better inside layout. I'll get the exterior looks out of the way because i really don't like it at the moment. Then I'll start inside detail.
    Keeping a nice smooth slab of a ship with good greebles might make for a nice look.
    toilet + crew room:
  • edseds0 Posts: 0Member
    as i said on LS-A i cant see much because its too dark but what i can see looks awsome :thumb:
    Started work on the modelling challenge:
