This is the fancy new sidebar. It offers quick access to your profile, messages, threads and so on.
Hit the X in the top right corner to dismiss this message.
Children of Sol WIPs
dreamwalkerdreamwalker177 Posts: 189Member
edited May 2016 in Work in Progress #1
Looking for some feedback on the general shape of this design.
The detailing and greebles are a long way off, but it's the same manufacturer as Lor, but approximately 1/3 the size.
Comments?
Post edited by dreamwalker on
«1345678
  • backsteptbackstept2 Posts: 0Member
    interesting
    can't wait to see more :thumb:
  • dreamwalkerdreamwalker177 Posts: 189Member
    The most flattering view I could muster
    Will post updates over the course of the next 20ish hours.
  • salsasalsa0 Posts: 0Member
    I am not going to lie. This thing is one ugly duckling, but it works for the most part, the only thing that bothers me is the depression in the "nose" of it. Is that going to act like a socket for some monstrous ball turret?
  • admiralducksaucadmiralducksauc0 Posts: 0Member
    I like it. It has a VERY strong shape and it doesn't come off as "from" anything else other than your previous work, which is awesome.
    i've been changing the engine structure, and i'm currently still, working on making the rear structure less fallic :D
    As for the depression, it's just part of the shape :)
  • BerkutBerkut0 Posts: 0Member
    sweet, another model by dreamwalker, we already know this is gonna kick a** when finished
  • MelakMelak171 Posts: 0Member
    Very solid shape, and I can already taste the smell of awesomeness in the air :D
    By the way, I like your avatar :)
  • liam887liam887210 ViperPosts: 547Member
    I saw your new models you posted recently so i know this will end up amazing too, just one question though your finished renders, are they 100% render including windows and lighting or do you achieve your results with some post production? Just curious?
    Your ships wouldnt look out of place in the EVE universe either good job!
    no idea on how to fix the stern. I can't wait too see ho this turns out.
    liam887 wrote: »
    100% just lighting and geometry, ie the station I made a while ago.
    More updates... (time for sleep...)
    I reckon one more 24 stint should do it.
  • OzylotOzylot0 Posts: 0Member
    Extremely cool!
    nice. What are your plans for the front.
  • RoninRonin0 Posts: 0Member
    great art. I like the basic shape ..
    but besides that, what role is this ship for ?
    i recognize engines ... many engines... is it engines ? or are those weapon-systems ?
    (as far as i can see they are pointes backwards :D )
    looks as there isn't much space besides the engines so .. what is onboard, or is this a fighter-scale craft ?
    want to see more
    salsa wrote: »
    I'm gunna add a bit more detail, plating and panels, and a few hundred antenna. Hopefully, it'll look cool.
    Ronin wrote: »
    want to see more
    It's primary role is as an armoured defensive platform. Secondary role is drone/nanite carrier/controller and it's size class is battlecruiser, 1km in diameter. Basically, it's a mobile wall of armour, used by fleets as line of sight cover.
    Your correct they are engines, i'll be adding some point defence weapon system hardpoints on the next stint.:cool:
    Updates...
    Still some errors to the front mesh which i'll sort out soon enough, and i'm also looking at refining the scale of some elements to properly define the ships scale (1km).
    About 80% there... woop! :p
    dude you're a machine. The speed you're doing this at is insane. Do you even sleep? Amazing work
    dude. Awesome.
    Annnnnd done!
    2.8mill polies
    4 days
    50 hours
    Time to work on the next model! :D
    Brilliant model! But uh...which end is the front again?
    Ozylot wrote: »
    Well, those blue/white lights are engines, if you consider which side has the most of them hopefully you could infer the primary direction of travel, but this is space, there's no up or down etc etc :lol:
    The reason it's designed as it is is due to it's role, it's a wall of armour, fleet commanders can position to use as mobile cover for units less durable. As it's armour instead of shields, it's harder to disable and doesn't require energy to activate. It's a philosophy that carries throughout that particular line of ships and can also be seen in action in it's bigger, older brother Lor. :)
  • SyklonSyklon0 Posts: 0Member
    Very cool, and fits in nicely with your other ships :thumb:
    Just posted this on the devart image.
    awesome, simply awesome.
    Test shape mock ups.
    This actual mesh probably won't be in the final model, it's just a demonstration of the shape of the ship.
    It's the Agni
    It's suppost to be a 200m-300m long assault cruiser. Cruisers in CoS are like short - mid range maurders, usually have 1-2 human crew. Assault roles emphasis firepower over speed and defensive capiblities, providing a specialised weapons platform. The top wing thingy as well as thruster clusters would probably house some turret mounts, with a main plasma lance placed in the center.
    It's a bit of a departure from the original concept below, but I seem to prefer these proportions.
    Any comments on the shape? (remember this is an alpha model)
  • Lee80Lee80192 Posts: 458Member
    interesting shape...
    cool. looks like it should be an interesting model like the last one.
    4 hours later...
    I dropped the wings, i'll be adding turret enbankments later but I tryed to first make a chassy that I could overay the armour.. Alot of work yet to do but it looks kinda promising :D
    reminds me of homeworld a bit... nice work
    Several more hours later.
    That's all for this week folks.
    Day 2 of modelling.
    14 hours later....
    I've still got to shot out the rear, the main cannon array and details. 1 1/2 days left I reckon.
    I'm not 100% sure about the scale of the details towards the front of the ship, and theres a few errors at in the engine block. beyond that, any comments?
    Great looking ship! Keep going!
