Local TutorialPhaser FX
MelakMelak171 Posts: 0Member
edited September 2014 in Tutorials #1
This tutorial's purpose is to create a phaser beam using 3DSMax 8 , but it should work fine in any application that supports mentalRay. Practically no experience is required, but it can speed things up.
UPDATE: I added a section that explains how to make the material properly animatable.
UPDATE 2:I rewrote most of the tutorial as I found a better way of doing it.
Preparations:
1: Unlock Lume Shaders
Before you start Max, you will need to make a tiny adjustment to unlock some
of the mentalRay shaders. Navigate to
"C:ProgramFilesAutodesk3DSMax8mentalRayShaders_standardinclude"
(or where ever you installed your 3dsmax)and open the "Lume.mi" file in any
text editor. Search for "glare", you will see an entry "hidden". Delete that line,
and the comma at the end of the line above & save.
2: Change Renderer to mentalRay
Start Max. Go to the Render Scene Dialog (F10), scroll all the way down to "Assign Renderer",
open it, and assign "MentalRay renderer" in the Production Renderer Slot.
3: Geometry
Create a thin cylinder, then apply a "UVW Map" modifier, and select a clydrical mapping option (just to be sure).
Now comes the fun part!
Updated 12/02/2008
4. Bring up the material editor (shortcut: M)
4.5 Pick any empty material, set it's self-illumination to 100.
5. In the diffuse slot of the material, create a "Glow (lume)" map, change all colors to an orange tone and set the brightness to 7. (Adjust this later if the glow is too weak or too strong)
6. In the opacity slot of the material, create a "Mask" map, (I named it "+ Irregularities" because it adds them)
and in the mask slot create a "Noise" map called "Irregularities". Use these settings as a reference, the size parameter depends on your scene scale though.
>> If you don't want a beam with gaps (somewhat like those in ST:WoK), leave out step 7.
7. Create another "Mask" map called "Gradient + Gaps" in the "map" slot, and create a "gradient ramp" called
"Pulse Gaps" like this one in the "mask" slot:
I guess this could've been confusing, this is what the material should look like in the tree view with step 7:
>>The material is done! Apply it to your pulse and let's go set the glows up!
8. Keep the material editor open, and bring up the Render Scene Dialog again.
In the "Renderer" Tab, scroll down until you see the Camera effects:
Camera Shaders section. Create a Glare (lume) map in the Output slot.
Drag it into an empty material slot in the material editor and choose Instance.
Change Quality and Spread to 3 and 3.5.
(Spread depends on the size of the glow you want):
This is about what you should get now:
>>You're basically done, render and see if that's enough glow for your taste. For additional glow, continue.
9. You can close the material editor and the Render Scene Dialog
now. Select your pulse, hit the right mouse button and select Object Properties. Set the Object ID to any
number you can remember,
and close the menu.
10. Open the "Rendering" menu and open "Video Post...". Hit the "Add Scene
Event" button (the one with the green butterfly) and click OK. then Press
the "Add Image Filter Event" button (~) and choose "Lens Effects Glow"
from the dropdown menu. click the Setup button. Be careful not to select any of the events while creating a new one, or you will stack the events and break animation rendering!
11. Enter the number you chose for your object in "Object ID", and tick "Edge"
instead of "All" in the Filter section. Go to Preferences and set the size to
1,5 and change the color from Pixel to Gradient. Go to the Gradients tab,
and edit the Radial Color gradient like this: 1st slider gets a yellow (R/G/B
255/216/0), the 2nd get's a full red, and then create one at position 28
with the same pure red. Change the 1st color of the Radial Transparency
to a dark gray (R/G/B 122/122/122), and create another one at position
43 (R/G/B 41/41/41). Hit Ok!
That's it! To render, click on the running figure button in the Video Post menu, select "Single", choose a resolution or enter one yourself and hit "Render" ! Here's my updated result. If you have trouble with the tutorial, Comment or PM me.
PS: If you want to animate the beam, you need to animate the X/Y/Z Offset parameters of the noise (and gradient ramp) maps:
Post edited by Melak on
  • stscifiguystscifiguy0 Posts: 0Member
    Do you have one for lightwave?
  • cilayincilayin0 Posts: 0Member
    I can't do step 9. Everytime I click on Output under the Camera Shaders there's no Glow. There's just "mia_exposure_sample" "Shader List (output)" "shaveMRHairComp" and "shaveMRRenderComp"
  • MelakMelak171 Posts: 0Member
    Make sure you unlocked the Glare Shader before you start Max, or else it won't be available :)
    I have no experience with Lightwave at all, sorry.
  • [Deleted User][Deleted User]0 Posts: 3Member
    very nice, will try later on 3ds 7 and let you know if it works, i've been looking for something like this for a while, thanks!
    I'm glad this is of use to someone.
    I think I will add a bit about making it animation-ready, so look for updates later today (it's around 4am here).
    Be sure to show your results :)
    here's a shot from a ship I'm working on, era - between ENT and TOS
    As you can see i changed the lighting parameters, everything else is the same. thanks, for a great tutorial!
  • NighthawkNighthawk0 Posts: 0Member
    anyone knows of issues when exporting to .tga?
    the lighting seems to screw up the pic if I render it to tga. with JPGs it's fine, tho.
  • EnterpraisEnterprais171 Posts: 0Member
    Perfect tutor! Phaser looks very good on static pictures, but not in animation...I make it here - http://www.youtube.com/v/Hq5L4Ubffjo you can see, that phaser's flares don't move while the animation...How correct this?
    Edited the tutorial, new section at the end contains info on animating it!
    Nice animations that you made! I Absolutely like Muse, fits the other video well!
    Hurrah!! It is working!! http://www.youtube.com/v/SYjgdlkNbn8 Great, great thanx for this tutorial!!!!
    Your beam casts a shadow, but I know that it's only a test. Looks nice tho!
  • joneshw01joneshw010 Posts: 0Member
    nice tute thanks I'll be using this info.
  • sxczcql666sxczcql6660 Posts: 0Member
    ^ ??? are you wondering if I ever updated it? Look at the bottom of the tutorial, there's the new part about animating it...:confused:
  • Chris VickersChris Vickers0 Posts: 0Member
    Is there a section in the tutorial about pulse-fire? That's what Galactic Command weapons are primarily (note that I use Vulcan cannons frequently in ship designs).
    No this isn't very useful for making pulses, but look for Acemans tutorial somewhere around the site, it explains how to make pulse phasers very good!
  • TeiTei0 Posts: 0Member
    My first post! Anyway, just to bump this, the pictures in the first part of the tutorial seem to be missing. I'm a complete noob to 3ds, if possible it'd be helpful to see those : )
    Duh, free imagehosting :(
    Gonna reupload them later today when I'm home
    Edit: Alright they're back up...I should probably make it a PDF some time. Sorry for the inconvenience :)
  • Jimmy_HJimmy_H0 Posts: 0Member
    Enterprais wrote: »
    Hey guy, can I offer a sugestion ? I used to use 3D Max. It has a flaw.. It doesnt' do animations correctly. There is a work around though. It creates still pictures perfectly. So. What I have done in the past is create each frame as a seperate picture (Like BMP for example) and then use another program like Movie Edit Pro (MAGIX) or Premiere (ADOBE). Either one of those will assemble your pictures together and create the animation. It can do it in the highest qulity possble for the size you have posted on your youtube site. Another thing I have noticed in MAX that doesn't do it in any other 3D software, is that your stars in your animation flicker in your animation. That is part of the problem in MAX. Again, it can be solved by creating still pics and then assembling them in another program made for animations.
    Just a suggestion guy.
    You described the way animation is done most of the time, but in fact video post can render to a video with effects.
    The "flaw" is the result of stacking the events in the video post editor the wrong way. Follow that part of the tutorial exactly and it will work properly :)
    I updated the tutorial, it's faster to complete now, and looks better ( to me)!
    i was wondering if this will work with maya because thats the only program i know and i am still very new to it so some of this stuff is kinda hard to figure out in a dif softwere.
    As far as I know it includes mental ray, so technically it should be possible.
    But that's about it, I've never had Maya so I wouldn't know where to look anymore than you.
    Note: The TOS settings are WAY different from the TMP/TNG effect in the radial color settings. I left the positions the same but I've made the following adjustments to that slot of the effect:
    Position 0: R=203, G=216, B=255
    Positions 100 and 28: R&G=0, B=255
    This produces a close knockoff to the Original Series [Remastered] effect, since the original cuts of the series show a multitude of beam colors ranging from red to off-white, since they never could make up their minds in those days.
  • MasterAccountMasterAccount0 Posts: 0Member
    can you fix the images, please?
    no problem
