yeah i was throwing around a few ideas in my head last night after looking through the various WIP's ive seen and also using some reference material and some brains i came up with a WarStar.
not a very good job on MS paint as compared to other ones i have seen but i suppose this will do untill i get DivX Draw.
there will be 2 more flight pods under the main body. i havn't had time to complete the side view yet. ive had a long drum lesson and its late so ill get to work after collage tomorrow.
Hav You Considered Making One Pod Out Of The Two Pods? Making It Adouble Width Pod? There Is Picture Of Original Warstar With The Dual Pods Underneath At Shpschematics.
for 2 good pictures of a Warstar try Steve Wilson's Designs at Colonial Fleets. For several unique 4 and 5 pods designs try Farquard's Graphics at Pegasus Actual.
i have now started to do the side view. i have done the head of it in as much detail as i can. the body does look a bit long but it will be shortend and made fatter.
at the moment i am currently making the flight pods.
as seen on pegasus there are 2 landing stips over and under each flight pod. but i also noticed the launch chutes are upside down aswell, now this does not compute with me becasue they would be loaded upside down and the artificial gravity in the ship wouldnt make that possible.
so i want a nice unique looking flight pod and either put 2 more on top of the main body of the warstar.
I always use PNG. I'm pretty sure that Paint can convert BMPs to PNGs without losing detail. If not, you can always download gimp or gimpshop to convert them.
Anyways, nice design. I like the intermediate-sized turrets. Larger than the mini-gun style weapons on the flight pods of Galactica, but smaller than the big guns. Nice work. :thumb:
i have redone the engines, made it a little shorter and started work on the flight pods.
i have used Battlestar Zeus along with mind allong with Peggy and Galacitca.
for a size comparison i hope The Kevin Show does'nt mind
this is alot more heavily armed than any battlestar and the flight pods are much larger holding quite a few squadrons of Vipers. it may look like a battlestarish but i have made sure it isnt to invincible.
yeah it is heavily inspired by Peggy. there are some bits n bobs i need to fiddle around with. but all in all its going well.
I hate to rain on people's parade, but I do have one minor crit.
This sucker is WAY over-armed. If you're going for some sort of realism, then you've unfortunately missed the mark. Not even looking into the structural issues of the turret's ability to traverse and the need for things like power generators, servos of some kind to allow movement, crew and maintenance access, etc. they are simply too close together.
Another issue is ammunition storage, access and capacity. With that many guns, the ship's ammunition stores will melt away fast than a snowman in Fiji.
Unless of course, you can't get ammo to the guns because you would need the most elaborate elevator system devised by man to get shells from the magazine usually deeper in the ship to the guns.
But like I said, that's just me because I try to keep my designs somewhat on the realistic side. But everyone has their own view of things and everything is based on fantasy anyways, so if you want to cover every square meter of your ship with gun turrets, that perfectly fine
thanks for your crit. i can see why you think it is over armed. i think i will remove 50% of the guns on the flight pods and some of the guns on the head.
but becasue i thought its a warstar it would be more heavily armed than a battlestar.
but yeah i did overdo it with the guns.
but the smaller guns are the anti raider guns and galactica has quite a few of them so i thought i would try and give the ship a good chance of holding off at leas 4 base stars.
any ideas were i should reduce the firepower? i would like it to cover all area's of the ship
im have taken a few of the guns off to make it a bit more realistic and i am debating weither to have rounded ends on the flight pods or straight ones. and i have re arranged the pod struts and making more progress on the plating
anyways here is are both with the 2 flight pod styles and a size comparson chart.
Howdy. Looking at the design it doesnt look bad. From The last 3 posts if I am correct in assuming that the guns I circled are the Small AA Guns I dont think shes over powered. It only leaves 12 of the Larger Galactica Guns on the flight pods which isnt bad. Although looking at it It does look cluttered> Just my 2 cents
you are indeed correct. those are anti fighter flack guns. and the bigger ones are indeed the rail guns that are seen on galactica but they are about 40% bigger so and the size of the shots will also increse. it is the newest ship in the colonial fleet and the very last war star to be constructed before the cylon attack.
here is a update less guns and a few bit and bobs added here and there
done the detailing on the engines, rounded the head section more, added some more guns since the last update to make it stand out from battlestar zeus.
Fighter squadrons - 400 mk7 vipers
Other craft - 50 raptors, 30 raptor gunships and 20 experimental multi role craft. (Unknown classification)
Armament - 80 multi role turrets, 36 heavy anti capital turrets. 4 missile batteries, 8 fixed forward cannons (as seen on Pegasus) and 12 nuclear missile tubes. With a compliment of 24 warheads.
10 drive engines, 2 FTL drives and manuvering thrusters placed around the ship.
Biography - Goliath was Completed 2 years before the cylon attack on the colonies, she was the first of the new class of warstar for the colonial fleet, warstar's were decommissioned or scrapped 10 years after the first cylon war as picon fleet headquarters debated the need for such large ships which were old and in need of a major overhaul, the last warstar named Orion was decommissioned on the 25th anniversary of the first cylon war.
8 years before the cylon attack colonial fleet decided that a new class of warstar was needed incase of a major cylon attack on the colonies.
The new warstar will feature the latest in fleet technologies including a new anti capital guns that are the same calibre as the forward forward fixed guns on Pegasus. a new anti fighter flack shell that can be fired from the her multi purpose guns which are the same as the guns on Galactica and Pegasus, a entirely redesigned computer system which is different used on other colonial ships which eventually ended up being used against them.
Goliath was commissioned on the 11th of October 2 years before the attack; she was immediately put on trials to prove her combat effectiveness. During trials she had manoeuvring problems due to her large size. Other problems included the loading mechanisms for the main guns which had never been used on a ship with such a vast number of guns, it was prone to jamming. As soon as she cam back from trials these improvements were made and she was re-evaluated and performed way beyond expectations.
During the cylon attack Goliath lead several other ships including, battlestars Tarus, Pacifica and Kobol and a dozen or so other support ships heading for Caprica were surrounded by 12 baseships and 1 very big unknown class of ship over the Colony Libran. Battlestar Kobol was the first to be destroyed when she suddenly lost power and all systems shorted out according to wireless communications between ships. The other battlestars and support ships perished shortly after with only 4 basestars destroyed. Goliath's Commander (Dante) ordered for a frontal charge and the firing of her forward batteries on the unknown ship, she managed to do considerable damage to it before the remaining baseships shielded the ship and caught the full brunt of her forward batteries in a last ditch attempt to even the playing field. she took out 4 more base stars. After a 40 minute stand off with the remaining base stars and the unknown ship she was evnetually destroyed with all hands lost. her remaining viper pilots watched horrificly as Goliath blew in half then her main reactor destroying the aft section hurling the forward section towards a basestar detroying it.
Shortly after the destruction of Goliath the Unknown ship jumped away never to be seen again.
Skeletor , check BSG ship and fighter designs thread for updates, and id load your updated tech specs on this thread.
i'll post them here for you , hope you dont mind.
Fighter squadrons - 500 mk7 vipers, 50 mk8 viper prototypes
Other craft - 20 mk1 raptors 25 mk 2 raptors, 30 mk 2 raptor gunships and 20 experimental multi role craft. (Unknown classification)
Armament - 80 multi role turrets, 36 heavy anti capital turrets. 1 missile battery (deployed at the top with 72 tubes) 8 fixed forward cannons and 24 nuclear missile tubes. With a compliment of 36 warheads.
Other features - Hydroponics bay for growing various foods, Production Workshops for building new vipers and raptors on extended missions, Flight simulators, Research Labs (again for extended missions) and the first ship in the fleet to carry a new non networked computer system.
Biography - Goliath was Completed 2 years before the cylon attack on the colonies, she was the first of the Orion class Warstars named after the last surviving Warstar from the first cylon war. The old Warstar's were later replaced by the Mercury Class battlestar which ended up in all surviving warstar's to be scrapped.
After the failed recon mission beyond armistance line 8 years before the cylon attack colonial fleet secretly decided that a new class of warstar was to be desgined and constructed incase of a major cylon attack on the colonies. There were 2 classes being desinged the Orion class and the Intruder class. both were very diffrent in design. the Orion class used its large flight pods which were double decked. she also had a much larger gun capacity than the Intruder Class and a larger ammo storage. but lacked in anti fighter supression. becasue it would need to rely on her fighters to stave off the cylon raiders while she would engage baseships.
The new warstars will feature the latest in fleet technologies including a new anti capital guns that are the same calibre as the forward forward fixed guns on Pegasus. a new anti fighter flack shell that can be fired from the her multi purpose guns which are the same as the guns on Galactica and Pegasus.
Warstar designs in the past had more than 2 flight pods, but designers noticed that it was unessesary to give these ships more bulk than they needed so they came up with a double sized flight pod that had the large fighter capacity but keep the ships profile lower and more Battlestar like giving her the advantage of being more manoverable and faster than older generation Warstars.
Goliath was commissioned on the 11th of October 2 years before the attack; she was immediately put on trials to prove her combat effectiveness. During trials she had problems with her loading mechanisms for the main guns which had never been used on a ship with such a vast number of guns, it was prone to jamming. As soon as she came back from trials these improvements were made and she was re-evaluated and performed way beyond expectations.She went back to the shipyard were she was constructed for some unfinnished work that needed to be done on the exterior of the ship, while she was docked she dwarfed all the other ships appart from the Intruder Class warstar that was weeks from completion and the other Orion and Intruder class Warstars which were also being constructed. The Orion class took longer to construct due to her size and the complexity of the hull desing, the 2nd Orion class warstar wich was to be named Centaurus was still in the shipyard during the cylon attack. the number of orion class warstars which were ordered was unknow but estimates show that there were at least 3 more under construction during the cylon attack.
During the attack Goliath lead several other ships including, battlestars Tarus, Pacifica and Kobol and a dozen or so other support ships heading for Caprica were surrounded by 12 baseships and 1 very big unknown class of ship over the Colony Libran. Battlestar Kobol was the first to be destroyed when she suddenly lost power and all systems shorted out according to wireless communications between ships. The other battlestars and support ships perished shortly after with only 4 basestars destroyed. Goliath's Commander (Dante) ordered for a frontal charge and the firing of her forward guns on the unknown ship, she managed to do considerable damage to it before the remaining baseships shielded the ship and caught the full brunt of her forward batteries in a last ditch attempt to even the playing field. she took out 4 more base stars. After a 40 minute stand off with the remaining base stars and the unknown ship she was evnetually destroyed with all hands lost. her remaining viper pilots watched in horror as Goliath blew in half then her main reactor blew destroying the aft section and hurling the forward section towards a basestar detroying it.
Intruder:
REVISION V1.6
This is a major revision!
INTRUDER CLASS WARSTAR SPECS:
Crew: 2000 to 3000, with a max evac limit of 10,000
Original Crew: 1500
Post Colonial home system evac Crew:444(raptors and gunships, assumes 3 per vehicle)280(Viper Pilots)64(multi role craft)
Total crew post evac estimate: 2288
Probable crew post evac: 3055(guestimate)
Fighter squadrons - 75 MK VII vipers, 50 MK VIII viper prototypes(alpha and beta models)
Other craft - 20 MK I raptors 25 MK II raptors, 30 MK II raptor gunships and 20 experimental multi role craft. (Unknown classification)
Post Colonial home system evac Auxilliary Vehicle count:165 MK VII Vipers, 120 MK VIII Vipers, 32 MK I raptors, 41 MK II raptors, 75 MK II raptor gunships, 32 experimental multi role craft. (Unknown classification).
Armament - 60 multi role turrets(planned ,40 actually installed), 24 heavy anti capital turrets(planned,18 actually installed). 3 missile batteries ,deployed at the top towards the bow with 36 nuclear missle tubes, With a compliment of 36 warheads,(additional 36 nukes available after reloading) and 20 standard missile tubes, 2 sets of 16 missle tubes located inboard of drive pod crossovers, 8 fixed forward cannons.
40 Point defense/Antiship minigun style Railguns.
Weapons system note: Intruder's guns can be used manned or unmanned as situations dictate.
Intruder's kew systems were modified late into the build phase to fire nukes, the net result is a warstar with a serious 'tude and a penchent for jammed magazine autoloaders(unintended consequnse of bein able to fire nukes this way) . her nuclear armament consists of 36 vertical launch missiles.
unlike most other colonial ships, she does have an external command tower.
however this is only used when performing docking maneuvers, or if spotting for the ships forward armaments is needed and is quite heavily armored as well as situated in between 3 different point defense stations.
*Weapons system note: all weapons in intruder class utilize a retract and cover scheme, to make it harder for an enemy with the element of surprise to disable her primary defenses.
Weapons system note:because of her ability to fire nukes from several of her turrets, the magazine auto loaders had a tendency to jam, this was because it was later determined to be a flaw with the autoloader design, the autoloader systems were later swapped for the same system equipped on the goliath class, solving the problem.
*Weapons system note: while her weapons loadout is less than that of the goliath class, the intruder class has 2o tons less magazine capacity and the same reserve ammo capacity as the goliath class.
*Weapons system note: Intruder also has a new weapons system based on the kew(kenetic energy weapon) designed for use against both cylon raiders and basestars.
it functions similarly to the ciws system mounted on a nimitz class aircraft carrier.
*Weapons system note: While the Intruder class has her primary weapon emplacements gruoped together into several Main batteries located dorsally and ventrally, some of the emplacements were mounted along the sides of the ship, such as the several emplacements on the sides of the forward hull, just aft of the bow, thus enabling broadsides to be delivered to the enemy while the ship is under power.
4 primary drive engines, 2 secondary drive engines, 4 FTL drives and 8 sets of variable position manuvering thrusters placed 2 on the bow, 2 on each drive pod(total of 4 on pods) and 2 on the aft deck.
note that each thruster group consists of 2 vents each(total of 16)
*Propulsion Systems note: Intruder class FTL modified for faster spinup, resulting in less prep time needed.
Other features - Hydroponics bay for growing various foods, Production Workshops for building new vipers and raptors and new types of fighters on extended missions, Flight simulators, Research Labs (again for extended missions) and the second ship in the fleet to carry a new non physical networked wirelessly networkable computer system.(wireless connectivity limited to inside of ship) and her own ore refinery.
*Note: her flightpods are more along the lines of flight bulges(for reduced vulnerability).
Recovery Bay was built into the ventral hull and surrounded with defensive turrets for protection, it was also for this reason that its located right beneath the central hull section connecting the drive pods.
*Note: the actual viper launch tubes are mounted dorsally and ventrally, and angled away
from the ship, avoiding vital structures. For this reason, intruder's vipers are actually required to land rotated landing gear pointed towards either the port or starboard walls of the recovery bay, depending on which set of launch tubes they were assigned to.
*Armor note:Intruder class armor is thicker than that of the mercury class.
and has bigger engines to compansate.
* Launch pods Weapons systems Note: several Rapid fire Ciws point defense turrets were carefully positioned to provide cover fire to both the pods and the vipers as they launch.
Recovery bay note: this bay can actually accomodate ships up to the size of a medium cargo ship. Typicaly these are slightly larger than the commercial transport that would later be known as Colonial One.
That size restriction allows for continued recovery operations even with a ship docked.
She also mounts an experimental dual or Dopplar dradis system designed to track and target at distances. this new dradis is also capable of directing the ship's ciws style kew to shot and hit multiple incoming missiles.
the warstar class was named intruder. a total of 30 were to be built. 2 were actually under construction at the time of the attacks.
All ships of her class except for 2 were assumed lost and destroyed during the cylon invasion.
Note: Because the intruder class was experimental alot of the operational details of some of her systems were restricted to ships personal.
She was built along side Goliath, using many of its systems, including an FTL system modified for faster spinning up, thus enabling faster jump prep.
Note: alot of the modified systems were installed on intruder and aries only, Their being prototypes, this was so the modifications could be tested prior to the modifications being implemented throughout both the Intruder and Goliath class'es.
Intruder was intended to be a test bed for a whole new generation of Battlestar.
Intruder class ships are named after people as well as famous places, events, etc.
*indicates details restricted to ships personel.
Historical and Biographical notes on the Intruder Class:
In developement since the end of the first colonial/cylon war, the intruder class warstar corrects several severely compromising flaws in the mercury class design.
The new warstars will feature the latest in fleet technologies including new anti capital guns that are the same calibre as the forward forward fixed guns on Pegasus, a new anti fighter flack shell that can be fired from their multi purpose guns which are the same as the guns on Galactica and Pegasus.
Though still in a semi incomplete state, the intruder and aries were commissioned about 2 weeks prior to the goliath due to a request from special operations command for the first 2 ships of the class.
bearing no resemblance to past battlestars or warstars, she was intended as a bridge towards a new class of battlestar.
In addition, The intruder class does have the capability to design and build additional starfighters as needed, so the small number of production prototype starfighters embarked on board is of no concern.
Built to be fast and tough, she sports multiple weapons emplacements and is capable of engaging at stand-off distances up to 3 basestars. Her armor is designed to shrug off all but the worst bombardments, enabling intruder to wade into any battle of her choice without fear. A planned total of 30 were projected to be built, however, dispite her advantages, of the 10 that were built, only 2 survived, brought down by the same trojan horse command navigation program that would see the end of almost the entire fleet.
warstars intruder and aries only survived because of the unique network system they had just been fitted with after their arrival at a top secret shipyard, and because special operations command refused to allow installation of the command navigation program.
It is known as a compartmentalized computer mainframe network.
At the push of a button, the entire network goes into localized systems mode, each part only operating systems in its area, with no physical or wireless links.
this system was thought to be the only possible solution in terms of allowing networked computers,while negating the possibility of remote hacking induced systems shutdowns.
Warstars intruder and aries were spared only because they had just been assigned to guard a top secret colonial fleet ship yard built and hidden in a nubula years after the first cylon war.
Rumors indicated that this shipyard was actually a long rumored command base for the colonil special operations command.
these rumors were comfirmed by the yard commander during the fight to evacuate the facility after the cylons discovered it.
They were assigned while still undergoing installation of some of their ventral and dorsal weapons emplacements.
While Intruder and Aries had complete AAA Coverage, neither would see their remaining weapons batteries installed.
The shipyard would later be itself destroyed, as would aries as she attempted to cover the evacuation of the facility, unfortunately, she was outgunned by 12 basestars. Her fighters and raptors would later be rescued by intruder who herself would suffer an ftl system malfunction, which resulted in her jumping right into the ionian nebula, where she would be adrift for 2 weeks before what was left of the human fleet, lead by galactica would find her.
Prior to the malfunction, Intruder would be dispatched to asertain the fate of the goliath, which was 1 hour overdue at speacial operations command, only to learn from goliath's surviving viper pilots what had transpired.
Intruder would leave The ruins of the colonial worlds, engaging numerous basestars, occasionally picking up ships and crews who had not yet learned the fate of the colonies, subsequently, upon returning to the hidden shipyard, Intruder discovered it under attack, and found aries being blown to bits.
Intruder was ordered by her commander(Conners)to cover the remainder of the evacuation, and to recover the aries's fighters and raptors.
Later the Intruder would encounter the Pegasus, just days after Pegasus abandoned the Civilian fleet she had gathered.
When Intruder's commander learned of this he immediatly left Pegasus against orders from Admiral Cain.
Commander Conners Explained to Intruder's XO that "he was not under Admiral Cain's Chain of command".
Intruder would later encounter the aftereffects of a pair super nova shockwaves.
The First Damaged a key memory file needed for FTL jump calculations, the net result of which was Intruder wound up 15,000 light years farther than expected, right smack in the middle of the Ionian nebula, adrift, and with a damaged FTL and navigational mainframe. The malfunction resulted in a depletion of 75% of her reaction mass.
It would take the better part of 2 weeks to fix the damage, only for Intruder to suffer a sudden unexplainable loss of power right after the unexpected arrival of a fleet of unidentified Colonial ships.
Power was restored 10 minutes after it failed, and after that the cylon fleet that was persuing galactica and its civilian fleet appeared.
As Intruder and Galactica Deployed fighters, both ships exchanged a rather hurried series of "who goes there" challenges.
The stage was set for a climactic showdown, colonials against cylons, unknown contacts, in short all hell was breaking loose.
List of planned and operational ships in the Intruder class:
Intruder- BSG 170 Status: OPERATIONAL
Aries- BSG 171 Status: DESTROYED
Apollo- BSG 172 Status: DESTROYED(while being constructed)
Athena- BSG 173 Status: UNKNOWN-presumed lost with all hands
Halcyon- BSG 174 Status: UNKNOWN-presumed lost with all hands
Endeavor- WS 80 Status: UNKNOWN-presumed lost with all hands
Herecleis- WS 91 Status: DESTROYED
Concordia- BSG 175 Status: UNDETERMINED
Pacifica- BSG 176 Status: DESTROYED(while being constructed)
Alteras- BSG 177 Status: UNDETERMINED(confirmed to still be maneuvering under her own power shortly before Goliath took 3 Nukes to her midsection)
Valiant- BSG 178 Status: DESTROYED
Avenger- BSG 179 Status: DESTROYED
Atlantis- *CSG 180 Status: OPERATIONAL(Location Unknown-Rumored to be special operations command's moble command ship)(* CommandStar Group)
Phendrana- WS 101 Status: OPERATIONAL(Location unknown-assumed to be with Atlantis as part of her support fleet.)
Remaining 18 ships of the class had not begun construction, as such they were not named or assigned to a ship group named
recon strike:
Version 1.0
Recon Strike
Specifications:
Size not known(my crud math skills are to blame yet again)
Weapons Systems:
X2 20mm Auto Cannon W. 850 rounds each (tungstun colbalt round with depleted uranium cores)
x2 All range Anti Starfigher Missles (modified Lancer Missile)
Defensive Systems:
Decoy dispensors(x2)
Jiggers
Drones
Composite Frame
Carbon-Carbon hull paneling
Other Features:
Advanced Multi mode Dradis built right into leading and trailing edges of hull frame
New Landing system:
Variable wings that fold for landing, absorbing and spreading the shock of landing to the whole airframe.(net result-no main landing gear required)
Advanced Digital Fly-By-Wire Control system(due to unstable lawn dart aerodynamics)
with built in EWS Protection Systems.
Armored "Bathtub" Cockpit
Advanced Canopy and Helmet Visor integrated Hud(with magnetic position tracking Targeting Control)
Propulsion:
Sublight Ion thrust drive(x2)*
*Note: Ion thrust drive requires less fuel for same range and performance as MK VII Viper
Advanced Integrated Short Range FTL Jump Drive Built By General Electric
RCS system: Varible position thrusters located on nose, wingtips, Aft Equipment bay.
Biographical and Historical notes:
Designed by earth's United Nations Space Defense Command and built jointly by General Electric, Northrop, McDonnel Douglas, General Dynamics, Lockheed, B.A.E., Dassault, Sukhoi, And Rockwell International in response to Lt. Kara Thrace's Warning of the approaching Cylon Fleet, and built to be small, light, Fast, and agile.
Utilizing the very latest in technology the earth has to offer, her very design was an international effort.
Built as a complement to the Defender class Earth Battleship, shes as hard to detect as she is fast.
One of these on its own is no threat, but whole squadrons pose the most serious threat possible.
Her composite hull makes her as stealthy as a B2 Bomber.
With agility and blindingly fast speed, shes as deadly as the very raiders shes meant to stop.
Using an advanced multi mode dradis, coupled with a helmet Hud, and magnetic tracking and targeting, combine to make her offensive systems, limited though they may be, exceptionally leathal.
Lt. Thrace would be sent back to Galactica with the specs for the recon strike, Earth's thank you for the advance warning, and incidentally as a way to identify the Colonial fleet as friendly, when they arrive at Earth.
MK VIII Viper prototype specs:
Type: Single seat all range Assault/Interceptor
Weapons Systems:
2x 20mm auto cannons with capacity for 2000 rounds of ammo each(assumes loss of Lancer Missiles)normal-950 rounds.
new mini missle system: Lancer Missiles- carried internally, max of 10 per interwing missle bay(unfortunate side effect of this new system is slightly thicker wings).
Upgradable to 25 per wing with use of slinger missile launcher pods.
external racks for standard assortment of viper missle systems and *tactical nukes
*issued only under last ditch desperate situations.
Defensive Systems:
Advanced composite armored hull
New wingtip pod mounted EWS (Electronic Warfare Suite)(both wings) installed for obvious reasons detailed below.
Propulsion:
Vertical take-off and landing capability
Other Features:
Advanced Multi mode Dradis built right into leading and trailing edges of hull frame.
Built in agumentation for the pilots lifesupport system
Advanced Digital Fly by Wire control, shielded by EWS(to prevent hacking attempts by opportunistic Cylon Raiders)
Her new design also incorperates 2 vertical and horizontial stablizer fins for increased atmospheric flight stability.
Misc Systems:
She is also capable of using a new system called the fast pack system.
this system is meant to give the viper capabilities it would not normally have.
Fast packs Currently under developement include the sete-(starfighter embedded tactical enforcer) status- currently in the flip a coin and hope it works phase.
Current Operational Fast packs:
FTL jumper pack- consisting of extra fuel pods and an FTL unit. status: undergoing developmental flight trials on warstar Intruder(max jumps:5-10 Depending on range and fuel reserves).
Bomberman Bomblet Despenser Pods-Status: Operational
Slinger Missile Launchers( 2 per wing), ups Lancer Capacity to 25 by removing the actual launching assembley from the wing and attaching the slinger pods.
Upgrade Report: due to the extreme miniaturization of the electronics on the recon strike, it was decided to overhaul all electronics on the MK VIII except the EWS.
the new, smaller systems enable an increased fuel and weapons load
the reason the ews on the viper did not recieve an upgrade was because the ews on the recon strike was designed specificly for the recon strike.
MK VIII Viper historical notes:
In developement for the past 15 years, she is an almost natural evoulution of the MK VII design, but built to fight.
Intended to replace the current MK VII airframe, only a modest 150 were produced before the fall of the colonies.
Powered by a pair of ion thrust engines, she has the same range and endurance as the MK
VII, using less fuel to boot.
Faster, Tougher, More agile, unlike past viper designs, she is built to take the fightto the enemy thanks to a prototype FTL jump drive fast pack.
Its speed is such that advanced digital fly by wire controls are the only way to keep it in the air.
Also capable of going toe to toe with the cylons new heavy raider thanks to her new and improved 20mm auto cannons and wing mounted internally carried Lancer missles.
Equipped with a revolutionary new advanced digital head up display that is also capable of displaying vital data directly on the helmet visor.
This system is also equipped with 3 magnetic sensors to enable shoot on sight.
Basicly, this means if the pilot can see you, you're dead.
This system is only available on the Beta Model and later models
Her Armament Was Further ehnanced by the lancer missile system.
Based on the javelen missile design, the "lancer" features an improved shaped charge warhead for improved stopping power.
These are carried internally.
This powerful starfighter can carry up to 6 externally racked missles for added firepower, of particular note is her capability to use dragon fly all range antiship missles, only issued under extraordinary cirumstances due to their capability to utilize nuclear warheads.
Unlike past vipers she as horizontal stabalizers for improved performance in an atmosphere.
Capable of using a number of mission specific fast packs for added capability.
(see techical specs above for details)
Because of her digital fly by wire design, and suspicions on possible cylon sabotage, she was designed and equipped with a pair of EWS Pods(Electronic Warfare System), designed to prevent remote hacking by enemy starfighters.
Projected for Fleetwide deployment(resuling in total phaseout of MK VII), only 150 were built and deployied before the fall of the colonies, 50 each aboard Intruder, Aries, and Goliath.
Initial deployments were targeted to the Intruder And Goliath class'es because they were just comming online and had been designed to deploy the MK VIII. retrofits would be neccesary for fleet wide deployment.
Built by a previously unknown ship design firm, spaceworks industries, she was initially to be marketed to local civil defense and civilan militias.
she caught the attention of top fleet brass while performing at an airshow on caprica.
During the airshow, she was performing some aerial acrobatics when a MKVII viper clipped her port wing, the test pilot, rather than eject, took a chance on the just installed vertical take off and landing thrusters, managing to save the vehicle and land her safely, testament to her ability to take a bad hit and keep going.
This got the fleet's interest right away, soon spaceworks industries had recieved enough orders to completely replace the fleet's stable of MK VII Vipers.
The unfortunate consequense was that this would require a fleet wide upgrade of the launch and recovery systems currently in use.
on an interesting note, the model that flew in the air show was the alpha model, a technology demonstrater.
later models such as the beta would come fully operational.
The MK VIII Viper, would be the first and indeed the only viper to use an ion thrust sublight drive, and the only viper to use HHTS(Helmet HUD And Targeting System).
During the recovery of the Goliath's vipers , the prototype MK VIII vipers were deployed.
The pilots reported unheard of performance while engaging cylon raiders attempting to pick off the surviving vipers from Goliath.
on a historical side note, the apache attack helicoptor also used a magnetic position tracking system combined with a specially designed Helmet, what this did is allowed the gunner to target the bad guy simply by looking at him.
Taking the kill was at this point simply a matter of squeezing the trigger.
More updates planned for later on over the next few weeks so please be patient.
Please note that changes will be made in these technical specs to reflect important stats of other ships tech specs.
This is to ensure as accurate a set of tech specs as possible, so some information may be in error.
If some one spots an error, or has a suggestion/change they wish included in these tech specs, please let me know, and i'll consider them, all i ask is that said suggestion/changes be as accurate as possible, preferably with a link to the original source material included in the suggestion/change request so that I may verify it prior to making alterations to these Tech specs.
Acknowlegements:
Some information in these specs was Quoted directly from the Goliath tech specs, due to the fact that they made sense, and it made sense for me to include that information for accuracy's sake.
Some information is based on information contained in the Goliath tech specs.
XRaiderV1.7226I have absolutely no ideaPosts: 1,074Member
glad you like the panelling I added to her.
the one who deserves all the credit is skeletor.
its his ship.
by the way, thanks skeletor, i would not have otherwise had this opportunity to learn and broaden my skills as an artist learning how to make his own art.
thanks Xraider, i love the panneling job. im glad ive helped you with your skills aswell.
im on my collage computer at moment. unfortunatly my pc has a trojan and my brother has taken it away to be reformatted. so all work is on hold at the moment unfortunatly. i will however keep sketching ideas and posting them on here as often as i can.
thanks again all.
hope your laptop gets better soon.
if you want, i can send you a few programs and utilities that i run on this machine.
they might help keep trojans away next time.
just let me know.
i was thinking on putting them ontop of the main body.
Just an idea:thumb:
Cool work by the way.
URL uploads are too small.
let my know what you think
cheers
done the top guns and more plating on the main body.
done some major modification to the flight pods. and better lettering. and made new pod struts that look abit beefier.
Length - 2400m (pod length 1000m)
Width - 840m
Height - 600m
Crew compliment - 4600
Length - 2500m (pod length 1000m)
Width - 840m
Height - 600m
Crew compliment - 4600 (max evac capacity 12,000)
Intruder:
REVISION V1.6
Original Crew: 1500
demensions:
Length - 2400m (pod length 400m)
Width - 800m
Height - 550m(with external Command Tower)
Recovery bay length:550m
recon strike:
Version 1.0
Recon Strike
Specifications:
Weapons Systems:
Defensive Systems:
Jiggers
Drones
Composite Frame
Other Features:
New Landing system:
Propulsion:
Weapons Systems:
Defensive Systems:
Decoy dispensors(x2) Capable of using:
Jiggers
Drones
Bug Zapper(new despensible jamming devices)
Propulsion:
Other Features:
Misc Systems:
Acknowlegements:
http://img.photobucket.com/albums/v106/ace1701e/AltWarstarGoliathMissileBatteryDepl.jpg
http://img.photobucket.com/albums/v106/ace1701e/AltWarstarGoliath.jpg
its his ship.
thanks again all.
just let me know.
