Sphynx's guide to Rapid-Prototyping
Converting your mesh models into real-world objects using STL and other rapid-proptyping techniques.
Introduction
This tutorial is being built over a period of time and will be running in conjunction with the 3D WIP thread '
Etherball: 3D mesh to real-world object'. This thread will contain all of the important information regarding what you need to know about rapid-prototyping techniques while the WIP thread is a major example of its implementation. Note however, that while that thread is using Blender to model, both threads are for the general membership and are
not Blender tutorials. All of the points raised as of equal importance for all applications in use.
As this thread is being built gradually, it would be extremely useful for now if any comments, requests and questions should be placed in the accompanying WIP thread rather than disrupt the flow of this tutorial. Any posts placed here which are not by myself will be moved without warning to the WIP.
In the same way, I am fully aware that there are several members who have professionally produced items for rapid prototyping in the same way as myself. If any of those members see things that I've missed as I deal with each issue, please post comments in the WIP and I'll incorporate them into the main tutorial pages as we go.
The first major point to remember...
I've produced quite a few meshes for rapid-prototyping so far - in fact over the last year, while it is far from being my staple workload, I've produced twelve meshes, a quarter of them for a returning client. From that, it's clear that I have quite a bit of experience in producing meshes for production as real-world objects - I know the requirements, pitfalls, and great feeling that you get when you see items that you've created on-screen sitting on the desk as a real-world object.
The most major point to remember however, comes before all of that. Make no odds - rapid-prototyping is a commercial and industrial process. It is designed primarily for use in producing master items for reproduction, and prototypes for industry. It is not designed for a private individual to transfer their prize 3D mesh into a desktop model, and the best reason for this is cost.
Rapid prototyping is expensive.
The accompanying WIP thread is being run on a piece that I am producing for my company to produce commercially - I'll be lucky if after half of the pieces needed I have change out of £1000.
A simple 98mm high figurine produced by the 3D printing company that I'll be using comes in at just under £100 before tax - on average that's £1 per millimetre of height even for the cross-sectional surface area of a standing figure, so be warned. Saying that however, you don't need to go over the top. Meshes that I've produced have ranged from a 9mm high TIE fighter, to a 200mm tall figurine, and there are many ways to keep the costs down.
So read on.
REMEMBER - Post all of your comments and questions in the WIP thread.
(links to be added as each part is completed)
What is Rapid-Prototyping
Planning your mesh
Building your mesh
Preparing and verifying your mesh
Bilbiography:
Note that various sources of industry information will be used in this tutorial in order to remain current with materials and methods available. Not least of which, are the public FAQ's available from Xpress3D.com, the Wikipedia and various rapid-prototyping manifacturers.
The Basics Concepts
The 3D object being built is sub-divided inside the computer into a series of thin layers that becomes a cross-sectional pattern for the 'gun'. The gun draws the cross-section into the basin, and the platform then descends by the thickness of that particular method's cross-section. Cross-sectional thickness can vary between methods, and the smoothness of the finished product usually directly correlates to the thickness of each cross-section. In the same way as a bitmap image onscreen, the larger the layer, the bigger the 'jaggies'.
Once the platform has fully descended into the basin and the 'gun' has finished drawing each layer, the gun retracts and the platform raises up again to let the remaining material drain away (if required by that process) and allow the object to be accessed.
Again depending on the individual process, the object may then need to be cleaned and then have a further process performed on it to finalise the material - some need a second curing process to fully harden the resins, while others may need to be sprayed with an additional finish.
The materials
Somos
The various Somos resins provide a range of properties including general fast production, accuracy, water-resistance, transparency, pure and clear white, and even high temperature resistance suitable for prototype testing.
Accura and RenShape
Both durable and accurate materials mimicking ABS plastic.
Polycarbonate/ABS
A mix of polycarbonate and ABS plastic. It provides both strength and durability and is widely used in the production of parts in the automotive, electronics and toy industry. It has good thermal properties and while able to produce the same detailing as ordinary ABS, it is significantly stronger.
ABS / ABSi
Reasonably strong and durable it has become an industry standard plastic. Objects made from ABS in rapid-prototyping have about 3/4 the strength of moulded ABS used in other processes, such as injection moulding. ABSi is similar to ABS, but translucent and with a significantly higher resistance to impacts (hence the 'i' suffix).
Polycarbonate / Polycarbonate ISO
Probably the strongest material available for rapid-prototyping. Like ABS, it has about 3/4 the strength of the same material used in a process such as injection moulding. The ISO version of this material meets the highest of the six standards used in ISO grading and is also suitable for sterilisation using either gamma radiation or ethylene oxide.
Plaster Powder / Starch
A plaster based powder that is infused by cyanoacrylate or epoxy resin to produce a very high resolution cross-section. It probably has the thinnest cross-sectional width available, and allows the use of multiple colours within the same object. It is invariably only used with the ZCorp and other inkjet 'inkjet' processes. Starch provides the same type of powder based media but is really not used for permanent objects - probably just temporary items which may see destruction anyway, such as in a master mould making process.
Various PolyJet Resins
Various resins providing highly detailed and smooth finishes. These materials generally provide a good impact strength as well as a slight resiliance allowing 'snap fit' capabilities.
TangoGray and Black PolyJet Resin
These materials are very similar to rubber or silicone and objects made from these materials can therefore be made to stretch over other components.
Duraform PA and GF
Duraform is a polyamide based material providing high durability. The GF version of this product incorporated glass beads.
Next: The various types of Rapid Prototyping available
