TLDR: Added option to add the CG apps you use to your profile. Cute little icons will show up in all your posts too!
Haven't added any features in weeks, so it was about time we MySpace the place up a little.
I've added something like 50 CG applications for you to display on your profiles and posts to answer all those
"what app do you use?" and
"what did you render this in?" questions for you. I'm not sure if that's an actual problem that needed solving, but here's a new feature anyway. As an added bonus we get a little visual bling on the posts. To add them, simply go to
Edit Profile, scroll all the way to the bottom, and then just check the apps you use. I would prefer you stuck to a few main ones you use daily instead of checking everything you've tried over the years to keep things a little tidier.
If there is something you use missing, reply this thread to let me know. Posting the icon as a square PNG with transparency will move things along more quickly in our end.
Added Lego, MagicaVoxel and trueSpace.
