This is a conversion from trueSpace to Blender of one of my later trueSpace sets that contains most of the common parts used in the late movie era bridge sets. The materials are left as they imported, which basically means you're on your own there, but I believe they are all at least set to Principled BSDF. As always with my second- and now third-generation sets, this was built to real-world dimensions based on the best available reference materials (for example, a cylinder 18ft in radius and 6'8" in height with the bottom set at world origin will correctly align with the top edge of the turbolift doors.
This set is free to use for parts, but as always please credit Sean Robertson for parts used. I'd obviously prefer to see some effort put into things, not just reusing this as is or simply rearranging and rendering - make it worth the bandwidth and render times. The objects are all organized into nested collections as logically as I could manage so you should be able to use Blender's append function to pull in any individual collections from the hierarchy that you want into your own project.
Shaded solid:
Wireframe, x-ray enabled:
Zip attached. Licensed under CC BY-NC-SA 4.0. To view a copy of this license, visit
https://creativecommons.org/licenses/by-nc-sa/4.0
Can I still convert it to c4d?
greetings
trekki
Great object!
