3DAnother TOS Constitution
CowardCoward220 Posts: 16Member
edited July 12 in Work in Progress #1
Long time lurker, possibly first time posting. Was inspired to do scifieric's blender tutorial on modelling the USS enterprise after seeing it mentioned in MikeFinleyMusic's thread.
I finished most of the modeling of the saucer and engineering sections and am currently working on the warp engines. While I am following scifieric's tutorial I have been using different modeling techniques for some of the sections and am planning to add some extra details, like window boxes and a hangar bay.
Edit: added a more current picture for the thumbnail.
Post edited by Coward on
FreakLizzy777P5ych0p4thevil_genius_180scifiericBrandenbergBolianAdmiralpubliusr
  • FreakFreak943 Posts: 4,099Member
    Very Nice. Eric Tut has to be the best out there on building this thing.
    Looks of info on the actual filming models and he holds your hand each step of the way on the build.
    Also think by follow Eric Tut it made me a better modeller.
    I look forward to seeing your finished model.
    scifiericBolianAdmiral
  • MikeFinleyMusicMikeFinleyMusic76 Posts: 29Member
    Love it!
  • scifiericscifieric681 Posts: 1,144Member
    Coward wrote: »
    Wow! Thank you for the mention! You have a very nice model here. Well done and I can't wait to see you finish!
    Freak wrote: »
    Holy cow! Thank you, Dean! You're very kind!
    BolianAdmiral
  • CowardCoward220 Posts: 16Member
    Thanks Eric. I've always liked seeing your various recreation of TOS scenes over the years, and I'm definitely enjoying going through your tutorial.
    Freak wrote: »
    I agree, all the info he supplies in the tut keeps it interesting and really helps when modelling some of the parts that have changed over the years; like the deflector dish, or the grills on the warp engines.
    So last night I finished modeling the trough details along with some other things on the warp engine. Spent to long on the grills, ended up redoing them 4 or 5 times. But in the end I really like how it all turned out!
    evil_genius_180FreakLizzy777ashleytingerBolianAdmiral
    Those grills can be a pain, but your has turned out really nice.
  • evil_genius_180evil_genius_1801488 Posts: 9,714Member
    Yeah, that's some really nice work.
    Coward
    Current progress. Got the front of the warp engines lighted and modeled, and added the missing details on the front engineering hall.
    Freak wrote: »
    The grills on my model are actually pretty simple to make, they're just a simple mesh with an array modifier which has a startcap and endcap added. The startcap and endcap are separate meshes that use an array to get the desired length and a SimpleDeform modifier controls the angle of the bend. Here's an image showing the three objects that creates the grill.
    Most of the problems I had making the grill was getting the SimpleDeform modifier working, and I also had initially modeled the wrong pattern for the holes in the grill.
    FreakLizzy777BolianAdmiral
    Nice. I assume that's a difference in 2.8 than my 2.79 version. Well done!
    Thanks! It's definitely possible to do it in 2.79, both modifiers are basically the same and the only major difference I could see is the SimpleDeform modifier has an extra option in 2.8 to control which axis it will bend on.
    I've finished all the modeling for now. Added some basic interior, added the rear light strips, and ended up redoing all the windows after realising they were all too short.
    I'm hoping to get onto texturing next, but I've currently got distracted and have been blocking out the hangar's interior.
    Nice Start on the hanger.
    Coward
  • ashleytingerashleytinger539 Central OhioPosts: 581Member
    It takes either a brave or crazy person to try and model the shuttle interior for the TOS ship and marry it up with the exterior. It looks great though!
    scifiericCoward
    It does look great. Really, as long as you don't try to line up the exterior windows, you'll be mostly OK. ;)
    scifiericCoward
    Oh man, that's pretty!
    BolianAdmiralCoward
    Thanks!
    I think I'm done with initial blocked out. I may do a bit more work on it, but I want to get onto texturing the exterior. Also at some point I need to resize everything, as currently the exterior is around 88m long.
    To help with scale I've added a human sized rectangle and a basic model of a shuttlecraft I had made for another project as a size reference.
    I'm leaning towards only slightly crazy =) . It actually ended up easier than I thought it would, probably helps that I'm only trying to make it look right and not trying to make it a accurate replica, because that way leads to madness.
    I'm trying to avoid doing that, but I already have one window box intruding into the front alcoves. The only good thing is there are only a couple of windows I'd have to move to make it work.
    FreakashleytingerLizzy777evil_genius_180
    I've finally started texturing and have mostly finished the top saucer. Need to decide if I'm going to add any dirt, kinda like the clean look.
    I've also done a tiny bit more work on the shuttlebay. I've added some initial materials, modeled the lift/turntable, and added simple rooms to the balconies.
    evil_genius_180publiusrLizzy777Freak
  • publiusrpubliusr244 Posts: 1,229Member
    Fresh outta spacedock
    Nice, I like the clean look with the Textures to. but it up to you what your want to do.
    That Shuttlebay is just getting better and better with each update.
    Thanks, I'm quite pleased with the shuttlebay, especially since it's hard to find good references on it.
    I'm definitely sticking with the clean look, any dirt I have added is very subtle and barely visible.
    Current progress; textured the engineering hull and saucer bottom, modeled some stuff for the shuttlebay door mechanism, and did a tiny bit of work on the shuttlebay pods interior. Finally integrated the forward arm thingy into the engineering hull, and moved the windows near the shuttlebay to be inline with the upper shuttlebay rooms.
    FreakashleytingerLizzy777furswiftevil_genius_180
    Nice and that shuttlebay does look really sweet inside the old girl.
    Oh man. That's all very beautiful work! Excellent job!
  • Hunter GHunter G230 Posts: 343Member
    edited July 7 #22
    Loving the progress so far!
    Coward wrote: »
    That cutout part is one of the hardest parts on the secondary hull. Kudos for getting it to look so good!
    Post edited by Hunter G on
  • Adam WarnockAdam Warnock45 Posts: 72Member
    Looking good. Doing a lot better than I would.
    @Freak Thanks!
    @scifieric Thanks! I wouldn't have got this far without your wonderful tutorial.
    Hunter G wrote: »
    Thanks. Surprisingly It ended up easier than I thought it would be. The hardest part was getting the flat area where it blends into the hull at the right spot, but I solved that by sloping the whole area slightly towards the front.
    @Adam Warnock Thanks. I had a look at your thread and I think you could do as good a job as me!
    I've basically finished texturing the exterior. I haven't put any textures on the neck, but it looks fine with only materials. Only thing really left to do is the shuttlebay, but I'm currently thinking of taking a break on this and returning to another project that I had put on hold to do this.
    scifiericevil_genius_180publiusrLizzy777ashleytingerZhor2395FreakP5ych0p4th
    Very, very nice!
    That looks outstanding. I agree, the neck is fine as it is.
    publiusr
    Looks really good.
    As for my ability to do this, there's a reason I'm doing my own stuff instead of someone else's. I really don't want to do the research and tryign to get it model accurate. I'd probably wind up making it my own anyway.
    That understandable. I've put some models on indefinite hold because I couldn't get them to look close enough to the reference images.
  • Chris2005Chris2005375 Posts: 2,990Member
    I'd say, add some post work on this and it'll look damn near exactly like the original. :open_mouth:
    @Chris2005 you got me curious what it would look like, so here's my quick attempt at replicating that classic look.
    And the render before post work.
    Freakevil_genius_180Lizzy777
    Nice, looks like you got it close.
    If you want to get it accurate to the look, speak to Eric. He is a master at it.
    scifieric
