3DLost, but found
BorgManBorgMan209 DutchlandPosts: 581Member
edited August 2019 in Finished Work #1
Aquapod DSV-01 makes its way to the recently discovered wreckage of an old Paris class vessel, where a base is being set up to research its demise. Seeing as the last time Starfleet had contact with the vessel was over 180 years ago, they're very interested in knowing why it's in a relatively good condition. Was the craft here all that time, or did it wound up on the bottom of this Class M's planet ocean later?
Post edited by Guerrilla on
Lizzy777
  • evil_genius_180evil_genius_1803864 Posts: 10,809Member
    It looks good. The only thing I'd suggest is maybe making it a bit murkier, especially towards the Paris class. As water is full of stuff, it gets harder to see through the farther away you are, so that would help better give the illusion of distance between the objects.
