3DDSC Shuttle
trekkitrekki947 Posts: 1,400Member
DSC Shuttle or. Object from Chris Kuhn
Thank you for this nice Object.
The Object is an .FBX Format you can download here: https://www.dropbox.com/sh/0nxw293akuabxaf/AABsOoEL5rgtEbT9ZkvQJ--za?dl=0&preview=DSC_Shuttle.zipu4i3jesyeurs.jpg
Lizzy777
  • trekkitrekki947 Posts: 1,400Member
  • billy-homebilly-home331 Posts: 22Member
    Nice conversion Trekki, I'm still finishing a LW 2015 conversion, but I'm still struggling to get both the yellowish and blue illuminated panels to match Chris' orinigal ones.
    Yeah, I do not know how he did it.
    It seems very easy in Blender.
    Chris works with Blender.
    I really like this shuttle. Nice job and thanks for the link.
    Made one with more Federation like hull color
    @Trekki, I ended up putting point lights in place of all those little polys, then made the glass surface 100% translucent, it works, but I think I need to add SSS into the mix, as perspex type materials also scatter light going through them.
    @Nightfever, Nice job, I did the same type of thing but screwed up a bit when trying to alter the registry and name on the sides, they don't quite fit because of the overlapping UV maps, so I'll just have to redo them and take that little oversight into account
    Someone at foundation 3D changed the textures to the look like the Galileo from TOS and it looks good.
    Yes , this is from Aggi !
    trekki wrote: »
    The only problem is that unless you have LW2018 you cant use it. it's too bad because I would loved to use it.
    Yes, you can use it. It is also included as a .FBX file.
    Here's the TOS version I did (with the decals fixed), I hope you like it
    It is not bad, the name is missing in the front area.
    Look here
    http://www.foundation3d.com/forums/attachment.php?attachmentid=85618&d=1555881267
    I know Trekki, I had actually forgotten about it, until I went to post the TOS images there, I'll have to edit the textures again to get rid of the red block on the nose first
